Old 05-12-2022, 09:20 PM   #84 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
If they can get wood for free, that's the way to go.
Sadly no. You'd think with all the dead forests they'd be paying people to clear them. I might actually go help some friends tomorrow who are fleeing from a forest fire south of here.
My current heat pump is a SEER 24 unit that will deliver full rated BTU down to 0F and reduced heat down to -22F. So that should likely cover most days but you may need to supplement with some wood.
If you get 4 feet of snow you put the outside unit more than 4 feet off the ground. Wall based mounting is typical in most of the world - I'm not sure why we mount most of ours on the ground in the USA.
There are days where it can get as low as -40°F. I guess I'd have to research what heat pumps would keep the home from freezing in a worse case scenario. There have got to be heat pump units that switch to resistance heat when it's too cold for the heat pump to opperate.
I had never heard of wall mounted heat pump unit. Thanks!
