Old 05-14-2022, 06:39 PM   #279 (permalink)
Drifter
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
25-0 would take maybe half the total time required. A constant uphill incline might speed things up.
I suspect you'd have to be extremely diligent to discern small aero changes with a 25mph coast down test since rolling resistance would be the primary force working against you at those speeds.
Your end on an uphill idea is a good one if you wanted to do quick & dirty A B A testing. Using flat ground (and averaging runs in both directions) would be better if you wanted to take your speed vs time/distance data and try to calculate your car's coefficient of rolling resistance & CdA in a spreadsheet.
