Why have you never mentioned it before?
https://en.wikipedia.org/wiki/Pressu...t#How_it_works
LED lamps of a specific wavelength are used to excite the pressure-sensitive probe within the paint. Once excited, the pressure-sensitive probe is transitioned to a higher energy state where it may either emit a photon or be quenched by local oxygen present. This competing process of emission and quenching determines the intensity response of the paint layer. The result is a dimmer fluorescence where there is higher pressure and brighter response at lower pressures.
The intensity emitted from the surface is then recorded through a long-pass filter by a CCD or scientific grade camera and stored for conversion to pressure using a previously determined calibration. Images of the paint layer are recorded at three conditions. A wind-off image at a known reference condition which is typically standard atmospheric conditions with the tunnel turned off. A wind-on image at a loaded condition where the wind tunnel is running at condition. And lastly a background image where the ambient light present is captured without the illumination source. The background image is then subtracted from the wind-off reference and the wind-on condition image in data processing.
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
