Old 10-13-2008, 12:20 AM   #18 (permalink)
Concrete
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
Xringer,
looking good
and I would not worry about increasing drag by catching airflow with the mini skirts
judging by Lunar's post you are in good company
but to crexcrex point I bring my own failed test data of full skirts
I did a quick test with scan gauge at 65 mph the cover shown below
they were at best no improvement & I do believe, as crexcrex said
trap the turbulence and cause more drag.
but...
I have open wheel wells in front of and behind my rear tires
(my truck bed is sort of hollow looking in that area)
I believe I was catching air from under the vehicle & not letting it equalize thru the wheel opening
you appear to have closed wheel wells - front and back
I predict you will be gaining on this mod
measuring it might be an issue if you don't have instrumentation
Hope this helps
waiting to see your results
might mod my card board wonder skirts to match
Name:	rear wheel skirts cardbard test1.jpg
Concrete
Start where you are - Use what you have - Do what you can.
