Old 05-19-2022, 05:46 PM   #32 (permalink)
aerohead
attached, stiff, stable
Originally Posted by Phase View Post
how would a rear diffuser even be attached for an ioniq hybrid and how would it stay stiff and stable?
1) Any existing holes can be re-purposed for attachment points.
2) 1/4- 20 all-thread can be cut, bent into a 'J' on one end, and slung over an existing rigid structure to create a tension member to 'hang' a subframe, skinned, and stiffened with aluminum angle extrusion, box-section, square tubing, etc.., 'pinched' against double-nutted fasteners, locked at the desired elevation for the panel.
Welded, brazed, spot-welded, bolted, self-tapping screwed, riveted, epoxy-bonded, etc..
You have exhaust heat issues, so that's got to be addressed either with custom heat-shielding, or the use of sheet metal.
10mm, fluted Coroplast would be stiff enough for non-heated locations. Throw metal at problem heat areas.
Spread compressive loads of attachment over wide fender washers, so as not to 'crush' the panel. Nyloc nuts cannot vibrate themselves loose.
Dzus fasteners are great! it your budget allows.
