Old 05-23-2022, 01:54 PM   #310 (permalink)
aerohead
spats
Originally Posted by Phase View Post
I’m assuming I’ll have to add a harder separation edge flare after the wheel spats are put on? The lower part is rounded. Wonder why they did that too…
When you do the rear skirts, the rear bottoms should be spaced out enough to allow for full-depth clearance to the wheels.
If you add a short tail, it will integrate directly to the trailing edge of the new skirts.
If you do a short box cavity, it's trailing edge will have to address a phantom aerodynamic integration to the back of the skirts.
