Old 05-23-2022, 02:22 PM   #311 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
When you do the rear skirts, the rear bottoms should be spaced out enough to allow for full-depth clearance to the wheels.
If you add a short tail, it will integrate directly to the trailing edge of the new skirts.
If you do a short box cavity, it's trailing edge will have to address a phantom aerodynamic integration to the back of the skirts.
I’m aiming for about an inch clearance around the wheels. Bottoms will have to curve and flare out a bit. Is an inch enough or should I add even more space?
The Following User Says Thank You to Phase For This Useful Post:
aerohead (05-23-2022)
