Old 05-25-2022, 09:12 AM   #22 (permalink)
Piotrsko
Generally I have found on aluminum blocks that when you get a leak somewhere (unless you're really paranoid about topping off coolant level) you start the head gasket failure routine.
The warpage of heads is a heating then rapid cooling process which mimics a stress relieving procedure which machine shops do between "billet" machining steps.
Air bubbles in the coolant do not promote even cooling.
