Old 05-25-2022, 04:35 PM   #14 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
One more thing to quicken engine warmup are coolant heaters that run on glowplugs. For example, from a Citroen Xsara:
The glowplugs use your 12v electrics to heat the coolant while you drive. Also these 50-150 watts put an additional load on your engine, on 1 hand warming it up even faster, on the other hand increasing the risk of draining your battery if you do it constantly on short trips.
I found these two old threads:
glow plug based coolant heater
Engine suplementary heating - Reduced comsumption/emissions/interior heating
