Old 05-25-2022, 09:40 PM   #7 (permalink)
freebeard
Quoth DDG:
https://nuskooler.github.io › enigma-bbs › art › mci.html
MCI Codes | ENiGMA½ BBS Software - GitHub Pages
Some predefined codes produce information about the current user, system, or other statistics while others are used to instantiate a View. General Information MCI codes are composed of two characters and are prefixed with a percent (%) symbol. To explicitly tie a MCI to a specific View ID, suffix the MCI code with a number. For example: %BN1.
Without going deeper it sounds like an escape code. Your answer would be here: www.bbcode.org/reference.php
But then vBulletin is a subset. forum.vbulletin.com/articles/vbulletin-5-connect-aa/reference
Including Custom PHP in Modules.
Created by: Wayne Luke Published: Mon 10 Aug '20, 2:05pm 2400 views 12 comments
We've created a new package that is intended to facilitate the replacement of custom PHP modules with custom Display Template modules. It also demonstrates how to create custom API functions in general. You will find this package attached below. Steps to replace a PHP module Module Edit the api/main.php file Find the customWidgetHtml function Copy your php code from the module into the function. Change the code to generate a string value instead of echoing content and set that to the $myhtml par...
SEE MORE | GO TO POST
But then [again] that may only apply to version 5.
