Old 05-26-2022, 03:03 PM   #45 (permalink)
sregord
EcoModding DIY aer.or
Maybe I should start with a belly pan?
I have this ...tickle in the back of my neck about the future of this MH(Moby)... and its sell ability.
An improvement that doesn't effect the look.
Curious: I see many using coroplastic to smooth the underside... good because of weight, 9#s- 5/32"-4x8 sheet, but needs a fair bit of "structure" to rivet or screw to.
Has anyone used 21#s- .181" -4x8 plywood, sealed/painted with epoxy (Patio/concrete paint). It has alot of shear, and "twist" resistance. Neither belong near hot exhaust obviously, but 3 sheets under a Honda would equal a 36# difference, but would require less brackets, & frames. Moby would need ~7 sheets
