Old 05-28-2022, 11:06 PM   #29 (permalink)
Drifter
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
All the (reputable) local machine shops are backed up 4-6 weeks so with a small amount of hope I decided to try and clean up the carbon from the valves & seats and lightly - lightly - lap the valves to see if they would seal. To save time in case it didn't work, I went straight to the worst chamber (middle cylinder on back head) which leaked water from every valve - prodigiously so from the exhaust side.
Each exhaust valve had a fair amount of build-up and the sealing edge looked a bit pitted - a bad sign for shade-tree mechanic sealing methods:
The combustion chamber before - intake seats didn't look too bad - I was confident they would seal with a little elbow grease:
Intake valve looked decent - only a couple rough spots:
The intake valves after soaking in solvent & a little elbow grease. Still a few rough spots, but probably lappable:
I forgot to take after pictures of the exhaust valves, but the sealing edge was still quite pitted. Lapping helped a little, but it really looked like they were going to need a proper grind. Anxious to test them, I popped them back in to see if they would hold water:
They barely weeped, so I'll still have to have a machine shop to a proper job. I hope if I clean & prep the head and bring it to them disassembled they might be able to get it back to me in a week.
The good news is the 4 valves I checked were within spec for length, stem thickness, etc. I don't have a tool to check the valve guides, but I'd feel comfortable running these valves in those guides for another 100,000 miles.
The Following User Says Thank You to Drifter For This Useful Post:
redpoint5 (05-29-2022)
