Old 05-30-2022, 09:01 PM   #5 (permalink)
XCRN
Originally Posted by Drifter View Post
I can see where a higher flow air filter would make a difference at higher loads, but at light cruise why would efficiency differ throttling with a filter vs a throttle plate?
Edit: unless maybe the ECU were to interpret the higher throttle position as demanding more fuel enrichment & less ignition timing even though actual power demand was equal?
The timing stayed consistent at 36 degrees and target AFR stayed at 15.5.
The Following User Says Thank You to XCRN For This Useful Post:
Drifter (05-30-2022)
