Old 05-30-2022, 09:03 PM   #9 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Most of this is due to unfortunate side effects of lawsuits and legislation specific to HK & USA
Certain EVs will charge up to 30 amps on 110vac but most override the EVSE signalling for high speed L1 giving you artificial 8 or 12 amp limits to limit to possiblity of fire damage to worn and cheap outlets
Outside the leaf with 30amp 110vac RV compatibility L2 has speeds up to 240x72amps sadly few onboard chargers ramp that high
Summary
Portable L1 (typical) 6-12 amps @ 110vac
660-1440 watts
Leaf 110vac EVSE up to 30 amps @ 110vac
3.3kw
L2 (USA) 10-72 amps (max) at 208-240VAC
2.08 - 17.28 kw
The US for lack of standardization does have lots of possibilities if the onboard charger supports
Always disappointed me that few EVs support 110vac at rates higher than 12 amps
