Old 06-02-2022, 01:21 AM   #14 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Piwoslaw View Post
Regarding the block under the gas pedal - Maybe a spring would be better? That way the pedal will stop when it hits the spring, say around 75% allowing economical driving. But in case of emergency, you can still floor it, just with more force.
Just like the so-called "dual-stage" throttle pedal that was fitted to some Volkswagens in Brazil in the '70s?
