Old 06-02-2022, 02:33 PM   #7 (permalink)
aerohead
L= 4-meters
Originally Posted by Vekke View Post
Got it I will make it 4meters long from front to back or you have better idea?. that picture seemed to be level. Will do same construction to template 1 and 2 also.
Whatever is 'easy' for you.
We just need the CFD to run at a super-critical Reynolds for the length.
If the 'Template' had an overall height of 1409.7mm, like many current cars, it's length would be 5394.8mm overall, 'long' by conventional standards, however, much shorter than some heavy-duty pickup trucks sold in the USA.
Also, the rear third of the car could be an 'extensible' elongation, as envisioned by the Germans in the mid 1930s.
Again, thanks for the consideration.
