Old 06-05-2022, 01:21 PM   #50 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by rmay635703 View Post
Sounds like it’s a step backwards from the volt
Volt allowed
Comfort- 6kw
Eco - 3kw
Fan only + “appropriate “ defog , humidity and temp setting was actually fan only
There is nothing Eco about using 3 kW for heat. I try to keep it at 1 kW or below. With my Spark EV I could do that because it had a simple knob - Clockwise = hotter / Counter clockwise = colder. The Bolt's automatic system will spike up to 1.5 kW then drop to 0.5 kw.
The Bolt does have a fan only mode that works in all vent positions.
The Following User Says Thank You to JSH For This Useful Post:
aerohead (06-13-2022)
