Old 06-07-2022, 06:41 PM   #6 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Oh! I forgot to mention. When screwing in the shroud use washers at least as big as the plastic heads of what held it in before. In my case, that was huge honking 1 1/4" diameter washers. That distributes the force over a larger area and make the shroud less likely to tear / crack / come apart.
Currently building Champrius 4.0! Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
The goal is 70 mpg this time around.
Stats from Champrius v3.2:
