Thread: Warlock Camaro
Old 06-07-2022, 07:16 PM   #1 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Warlock Camaro
Thought I would introduce my 71 Camaro.
Not your ordinary 2gen Camaro this one will be powered by a 2.0L 4G63 four cylinder. It will be running one of my stratified lean-burn prechambers. The transmission will be a 4L80E with a lock up converter.
This setup will also be a dual-purpose FE/HP car. Goals are for it to run low 8's @ 170+mph, and to be able to get 45+mpg Freeway.
Mods:
Weight reduction down to 2800lbs with driver.
Improve Cd to .27 or better.
Lean burn with A/F at 30:1 freeway and I don't have to have any emissions other than a PCV valve
Fuel: pump92 for the street, GEM 47 for the track and waste solvent when I'm broke.
My wife and I will be doing a YouTube on the build starting next month.
ID:	32328   Click image for larger version
ID:	32329   Click image for larger version
Pressure Gradient Force
The Positive Side of the Number Line
The Following 5 Users Say Thank You to pgfpro For This Useful Post:
Cd (06-07-2022), ksa8907 (06-09-2022), redneck (06-07-2022), redpoint5 (06-07-2022), wdb (06-12-2022)
