Old 06-08-2022, 10:30 PM   #62 (permalink)
cRiPpLe_rOoStEr
Originally Posted by mpgmike View Post
Isn't that what we want inside a combustion chamber? Doesn't that explanation cover what an Expansion Medium is supposed to do?? Thank you!
As long as there is enough Oxygen to react with the fuel, and the Oxygen contained on water is not useful for that purpose, we couldn't rely so much on water inside the engine, even though some moisture occasionally may lead to a more homogeneous spread of the heat within the combustion chamber under some circumstances.
