Thread: Prius 75-91mpg
Old 06-09-2022, 11:59 AM   #271 (permalink)
Nathan jones
Ecomodding Apprentice
Well I'm on holiday but it's boring, lucky I brought cf. I changed the oil and while I was at it decided to make the horn/radiator bracket. I didn't make the side piece because I wasn't sure if it would earth very well so don't need that bit and will mount the horn on the Al crash bar. Also been meaning to saw off the tiny handle for heavy folk brackets. There's a few more when I get time. With an undisclosed but legal part removed also and a few 6061 bolts going in 2.21kg removed so far this week
Also there was some epoxy left over so I used it to glue one end of the 6063 homemade bolts for the trestle. Threaded rod m8 was 9 quid a metre!! Listed wrong most likely, usually 90
Also a horn bracket was not needed. 1980's Toyota parts
ID:	32341   Click image for larger version
ID:	32342   Click image for larger version
ID:	32343   Click image for larger version
ID:	32344   Click image for larger version
The Following User Says Thank You to Nathan jones For This Useful Post:
Ecky (06-09-2022)
