Old 06-09-2022, 07:36 PM   #6 (permalink)
R.W.Dale
LE Camry - '03 toyota camry LE
90 day: 32.63 mpg (US)
In aeronautics there's really two kinds of drag
Induced drag and parasite drag
Everything related to induced drag would be load bearing this is the drag from the airfoil form
Parasitic drag could be load bearing. But it can also not be any more complicated than keeping air out of cowlings and spaces. Or not installing some thing onto the fuselage that protrudes into the slipstream. It is actually OK to use tape on commercial aircraft in some of these instances
A good example on our cars would be anything perpendicular to the airflow will need to be rigid enough to not flutter which would be worse than it not being there
Anything parallel to the airflow like a wheel skirt also doesn't need to flutter but at the same time sees much lower aerodynamic loads
Too much junk to list. From a 10mpg caddy limo to a 5 speed Saturn
The Following 4 Users Say Thank You to R.W.Dale For This Useful Post:
aerohead (06-13-2022), Blacktree (06-10-2022), Ecky (06-09-2022), steve05ram360 (06-10-2022)
