I suggest wobbly extensions where the end is tapered, thinned, and lengthened so the socket can bend up to 15 degrees along with loose fitting drive ends on the socket. Harbor fright and couple of short cheapo black oxide air tool wobble extensions and sockets...minimum of 1/2" drive
Knurled pistons and perfect circle rings? Widen the compression groove and use 2rings?
(But not with a .5mm overbore [wait a minute my phone says thats .020" within the honeing range]) Sand blasting the outside of the piston skirt?
Back in the day kind of stuff for unobtainium parts mods.
