Old 06-10-2022, 04:32 PM   #66 (permalink)
mpgmike
The earliest controllers were wired direct. If I had to make a change, this made for way too much work. I had the wiring harnesses apart many, many times.
Later, I tried to use a somewhat standardized connector that could be reused with later versions of controllers. I'd get at least 2 if not 4 versions before having to wire in new connectors. I landed on Cinch enclosures & connectors. They are water-tight, and the connectors are top-notch.
Recovering Gasaholic
