https://www.alibaba.com/product-detail/Small-Wind-Generators-500w-5KW-10kW_1600354350838.html?spm=a2700.g
Hello! I can't post links yet...Im going to try it in the title of the reply..
Scroll down to the product description -- to see those ratings-
SX-600
SX-800
SX-1000
SX-2000
SX-5000
SX-10kw
Different ratings different weight/kg,
And yes the m/s -- is different on different designs.
Some are rated higher than these (kw) with lower weight .. and lower price.. the manufacturers - direct -- are sometimes selling them $40-200..
Have no idea whether the ROI would be worth it... ! Especially modding one of those. They can be wound though... and by hand.
BUT, if a lighter model turbine.. with high current -- could be used for hybrid's (or an alternative alternator install location-- like near the rear wheels/axle with lower rpm) .. it's an idea that could find it's place in a newer car design (if it hasn't already).
Or aero engineered car designs -- things could be tried with a small turbine horizontally factored into a boat-tail or something - pointing away from the car... especially if the outflow could create some kind of alter-drag, I mean a drag that doesn't effect the vehicle so much.
** Edit - Like; a turbine mostly covered up where the air just clips the blades on one side.. since the m/s meters per second is so low.**
It's the rpm's (on these versions) that would pose a problem in an engine - as an alternator replacement.
This could potentially fall under the category of full car design I guess.... like designing something into a rear axle on a fwd as an alternator replacement location... or another gearbox off the transmission. The weight of the vehicle could push it passed a point at which the drag would be far less than the power output.
Just ideas -- Off the top of my head.. since the maglerv stuff open's some possibilities up.
If you do a long search, you can probably find a better design than the one I posted from alibaba - and sometimes less costly.
Just an idea!
