Thread: Gasoline VAPOR?
Old 06-13-2022, 12:39 AM   #29 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by racprops View Post
Each engine has a BSFC and BSAC fingerprint.
BSFC can only be measured on a dyno. The formula is: BSFC = lbs. of fuel used per hour ÷ horsepower For example, a 300hp engine using 150 lbs./hr. of fuel would have a BSFC of 0.5. Different engines using different fuel types will have different BSFC values.
Well how much fuel is my 03 Ford Explorer 4.6 in 5th gear (overdrive) into a 3.73 rear end using when I drive it at 49MPH which is 1500RPMs and it shows it is getting 30MPG?? Steady running…how much HP and torque is it making?
Also same question for a 2000 Mercury Grand Marques, Well how much fuel is 4.6 in 4th gear (overdrive) into a 3.27 rear end using when I drive it at 65MPH which is 1700RPMs and it shows it is getting 30MPG?? Steady running…how much HP and torque is it making?
Same car running a 16.4 A/F ratio gets 35MPG same specs.
Trust me I know what BSFC is.
I'm not going to play this game. Been here and have done it 100 times, probably 20 times on this forum. If I we're to play your game you left something major out... "engine load" I would need to know what it is and it can be measured in kPa, inch/hg or psi I just need one of them to solve for it.
As far as the Mavrick guy. I had the inputs I needed.
Fuel type
Load inch/hg
IAT's
DA
AFR
BSFC load Map for a 302 Ford
Bore
Stroke
Compression Ratio
RPM
Rod length
Ignition timing BTDC
Cd
Transmission type
Anyway, I hope you find what you're looking for and prove me wrong. Like I said I already tested a vapor carburetor on my lawn mower engine. My results were no improvement in fuel consumption. Same EGT's and cylinder temps with the same AFR.
Good Luck
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Isaac Zachary (06-13-2022)
