Old 06-15-2022, 04:36 PM   #3 (permalink)
freebeard
Welcome to Ecomodder.
...tiny, hydrodynamic, underpowered ones? As usual, the use case is a constraint. Speed/range, capacity, deck area.
Here's a technique for massive ships that should scale down:
Catamaran for deck area. www.youtube.com/results?search_query=tech+ingredients+catamaran
How Many Solar Panels Do You Need For A Trolling Motor?
klbuckyians.blogspot.com/2009/03/mechanical-jellyfish.html
One of his [Buckminster Fuller's] early inventions was a mechanical oar patterned after the motion of jellyfish. "It consisted of a tepee-like cone mounted on the end of a pole and resembled an inside-out umbrella. Standing at the rear of his boat, Fuller would pull the pole toward him through a large iron ring attached to the rear of the boat. As the peak of the umbrella-like invention pointed toward the boat, it displayed little resistance. However, when it pushed backward into the water, the cone opened, propelling the boat forward."
You can't be wise and in love at the same time. -- Bob Dylan
