Old 06-15-2022, 10:13 PM   #5 (permalink)
freebeard
So.... two to four passengers, short range. All weather year round performance.
Would you have a boathouse on the home end?
M-hull:
https://www.soundingsonline.com › news › m-hull-new-thinking-in-boat-design
M-hull: new thinking in boat design - Soundings Online
Thanks for watching! "The M-hull eliminates the speed limitations of displacement craft," says M Ship co-founder Chuck Robinson. "It's a major breakthrough in hull design because the more pressure is captured in the hull tunnels, the higher the boat rises out of the water, the faster it goes and the less draft it has.".
https://www.brighthubengineering.com › seafaring › 57366-learn-about-m-hull-technolgy
Designing Ship Hull - What is M-Hull? - Bright Hub Engineering
M-hull technology is an innovative development that uses a specifically M shaped hull to create an air cushion below the vessel in order to reduce the air drag. The M shaped hull captures the bow wave energy to form an air cushion, which thus reduces the drag. The reduction in drag provides exceptional speed to the vessel, a trait that ...
The wages of woke is broke[™] -- Harvey Cthulhu
