Old 06-16-2022, 03:33 AM   #34 (permalink)
Drifter
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
So the block has definitely been rebuilt in the past because as far as I know, Mahle does not make Toyota's pistons:
One of them shows scuffing on the skirt:
That cylinder bore doesn't *look* bad, in fact most still have pretty good cross hatching. But this other cylinder does not. I find it odd that the cross hatching is worn on the side of the cylinder rather than the normal wear from the crankshaft stroke:
The bearings all looked to be in like-new condition except the main bearings on #1:
Crank walk maybe? Bent crankshaft? I'll double check tomorrow, but I think the abnormally worn cylinder crosshatching is also cylinder #1...
ID:	32371   Click image for larger version
ID:	32372   Click image for larger version
ID:	32373   Click image for larger version
ID:	32374   Click image for larger version
