if you turn the key back too far it will lock your steering column and since you have an automatic you would have to stop your jeep because it may not start in drive. since i have a standard when i come to a stop sign i can cut my fuel injector and use the motor as a engine brake and not use any fuel, or i can shut down the engine and not risk locking my steering column. more of the less just a saftey and convienece issue.
