simple rear wheel fairings
Not sure if this will link. If it does, it's cedar, open cell polystyrene foam, brushed-on polyurethane barrier coating to protect foam from polyester-based filler, BONDO, primer ,paint, back-fastened wheel fairings behind SPIRIT's rear wheels, attached from the top down. https://ecomodder.com/forum/attachme...4&d=1249763104
Reason: correction
