Old 06-18-2022, 09:30 PM   #355 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Originally Posted by Phase View Post
A thick aluminum sheet that’s a few inches from the muffler in the rear should be safe right?
Hey Phase!
I did a lot of research on cat shields (since I installed two of them on Champrius recently). All of them have slits / louvres / some kind of airflow through the shield. So while I don't think there's any danger to the aluminum sheet (melting point is 1200F or somesuch), there's probably some engineering reason to make sure there is still airflow around the cat / muffler / hot stuff.
Anyhoo, it might be helpful to look at different cat shields to get an idea:
https://catshield.com/products/2004-...n-2-cat-shield
Most of them seem to have around 10%-ish of the area devoted to airflow.
Hope this helps!
Currently building Champrius 4.0! Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
The goal is 70 mpg this time around.
Stats from Champrius v3.2:
