Old 06-18-2022, 10:48 PM   #356 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Originally Posted by Talos Woten View Post
Hey Phase!
I did a lot of research on cat shields (since I installed two of them on Champrius recently). All of them have slits / louvres / some kind of airflow through the shield. So while I don't think there's any danger to the aluminum sheet (melting point is 1200F or somesuch), there's probably some engineering reason to make sure there is still airflow around the cat / muffler / hot stuff.
Anyhoo, it might be helpful to look at different cat shields to get an idea:
https://catshield.com/products/2004-...n-2-cat-shield
Most of them seem to have around 10%-ish of the area devoted to airflow.
Hope this helps!
i just ordered this- Falken Design 36 in. x 72 in. x 1/8 in. Thick Aluminum Composite ACM Brushed Silver Sheet
its pretty much stiff dibond. ill be cutting out venting around the muffler
will need a way to drill into body panel to attach it
will be using welding tools or heat gun to add a slight 10 degree curve towards the end and then will build a rear diffuser from there
