Old 06-19-2022, 12:57 AM   #358 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Why? That could anneal the metal, and possibly discolor it. A brake or roller could work it cold.
Is the curve on the 72" dimension?
well idc about color too much since itll be under the car
and yeah itll be along the long ways
the rear panel only need to be 60 inches, but 72 was the only size above 48 they had
im going to be redoing my front undertray/splash pad thats been torn up from hitting parking curbs and road debris
heres my full order
Falken Design 36 in. x 72 in. x 1/8 in. Thick Aluminum Composite ACM Brushed Silver Sheet ( rear under try)
Falken Design 24 in. x 36 in. x 1/8 in. Thick Aluminum Composite ACM Black Sheet (2) ( rear fender skirts)
Falken Design 48 in. x 96 in. x 0.125 in. Thick Acrylic Black Opaque Sheet
( home depot didnt have abs plastic but this should be good enough i think- front under tray will be smoother with less venting holes, and also will cover more surface area under the car. will probably use left over plastic to build a rear diffuser extension inspired by the mercedes eqxx vision car)
The Following User Says Thank You to Phase For This Useful Post:
freebeard (06-19-2022)
