Old 06-19-2022, 03:26 AM   #38 (permalink)
Drifter
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
As a plan B I'm trying to find what other used engines I can get since the number of wrecked 2006-2010 highlander hybrids & Lexus RX400h is pretty low and all locally have high miles. But the 3MZ was also used in the Camry, solara, es330, rx330, highlander, sienna - so if there is some minor difference maybe I can just reuse my oil pump or dipstick or whatever...
So far I can see that the longblock part number is the same for 2006-2011 Highlander Hybrids, 2006-2008 RX400h, and a handfull of 2006-2009 2WD Highlander non-hybrids.
Toyota has a separate part number for the longblock for earlier Highlanders, 3MZ Camrys, 3MZ Solaras, and the RX330.
The Shortblock has pretty much the same part number breakdowns - the highlander hybrid & RX400h have their own.
The Block sub-assembly, however, covers most of the 3MZs (mainly excludes not AWD Siennas).
Pistons use the same part numbers between hybrid and not, highlanders, camrys, solaras, siennas, etc.
Rods also use the same part numbers
crankshafts also use the same part numbers.
Bearings are the same
...The only different part number I can find is for the piston ring set - the highlander hybrid has a different set.
But when I look at the service specifications, the ring gap is identical between hybrid and not. The engine bore is identical. Piston to wall clearance is identical. But the piston diameter specs are actually different by about 1 thousandth:
3.6202 to 3.6207" for the highlander
vs
3.6211 to 3.6216" for the highlander hybrid
The Mahle pistons I have are measuring about 3.6205" so they were probably meant for non hybrid. But Toyota specifies the same part number for both??? 13101-20050
Long story short: All of this makes me think I may be able to use a 3MZ from a camry or sienna or something if the machine shop says my core can't be reused. But it makes me wonder why the hybrid would use different rings/pistons?
DNJ has different part numbers for hybrid vs non hybrid engine rebuild kits so presumably they felt it was important enough for a different SKU: https://www.enginepartstore.com/toyo...e-rebuild-kits
