Originally Posted by larrybuck
You disconnect your terminal screws, put your additions on, and fight with the loose nut at the base of the terminal box to get it lined up and high enough to accept the threads.
I've had the same frustrating issue in the past.
I cut down a couple of longer 5mm screws to be just longer than the originals, then used them with each battery I've replaced since then (two and counting).
