Old 06-20-2022, 01:43 PM   #9 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
For what I understand, they are mounted backwards: the blunt should be facing rearward. So what is your logic process to install them?
They are mounted correctly. Different VGs have different orientations. You might be thinking about triangular VGs, which are often placed fat side to the back of airflow. These are aerofoil VGs called Gaspods:
https://aerohance.com/
As for the logic process... I detailed that just a few posts ago:
https://ecomodder.com/forum/showthre...tml#post669668
Let me know if you have more specific questions.
Champrius 4.0 is finished and up
FOR SALE.
Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
Stats from Champrius v3.2:
