Old 06-21-2022, 03:46 PM   #18 (permalink)
freebeard
I'm finding triangles overlapping rectangles are particularly effective.
Not getting the over and under part.
If you look closely the design at #16 is based on an octahedron. There are four-way connections at the front, rear, top and sides. This is what allows the differential prolating.
Also, the triangles can be rendered as diamonds or hexagons. The triangulated shell over a diamond frame would [technically] be triangles over quadrilaterals.
edit: look what I found, A Wellington but instead of showing it's Lamella frame, it's under a canopy that is diamonds over squares.
http://www.airpowerworld.info/bomber...wellington.jpg
Embed is thwarted.
