Old 06-21-2022, 05:01 PM   #3 (permalink)
oil pan 4
FtMain thing is don't run wide open throttle under lean burn, the exhaust valves will get burned. Been there done that.
That's why I like lean burn tuning 4bbl carbs. The primary venturi are for driving around town and even highway driving.
The secondary venturi are the fuel dumps.
Primary gives an air fuel ratio of around 16:1. Then when you floor it the taps open and lower the air fuel to more like 13:1.
I ran my 7.4L suburban like that for at least 9 months, I pulled the head to replace a head gasket that was bad when I got it. None of the valves were burned.
The engine in destroyed had electronic fuel injection and ran lean all the time.
twj347 (06-23-2022)
