Old 06-22-2022, 10:31 AM   #104 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
71 Camaro - '71 Chevy Camaro
White Pearl - '26 Toyota Prius SE
Originally Posted by mpgmike View Post
Not sure of a technical reason, but we used parts store sensors and fought with fuel economy gains. After way too many hours of frustration, we tried OEM O2 sensors as a last resort and -- what do you know? We got the gains!
Cheaper sensors will get rid of a DTC, and the ECU doesn't complain, when everything's stock. But even then, they don't seem to get quite as good fuel economy as the OEM sensors.
Best I can tell is it probably has something to do with calibration.
I agree I think you have to watch out with aftermarket O2's sensors. I have a fake BOSCH WB that reads 14.7 all the time.
Also I'll add on my setup I run in open loop all the time for fuel economy. If I run it in closed loop I can't run my car very lean and get miss-firing. I think it has to do with the oscillation of closed loop.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
mpgmike (06-22-2022)
