Old 06-22-2022, 02:29 PM   #1 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Question Ideas for aero-ing a piano hinge?
Howdy all!
I'm currently designing a nose cone for Champrius. The key to the nose cone will be a variable area inlet for the radiator right at the tip. I've bought these piano hinges:
https://www.amazon.com/dp/B07PP1XXQT
and plan on having a 24" x 3" opening for the inlet, with one hinge on top, and the other on bottom. That will give me 0-72 sq ins which should be enough to cover all cold to hot weather conditions. Viewed from the side, it's basically the leading edge "front" of a triangle whose base is the radiator (though with some more curvature to guide airflow).
Everything I've read says that aero-shaping for radiator inlets is crucial to proper airflow. It's the reason why virtually every grille in the world is inset slightly in some kind of curved bumper / fender. So I want to make piano hinges like little aerofoils / curve them smooth somehow.
Does anyone have any ideas on how to do that?
Keep in mind the main constraint: whatever we do has to be tough. This part will, without doubt, receive more wear and abuse than every other aeromod on the car. Not only does it have to withstand a constant +15-60 lbs per sq ft of pressure above atmospheric, it's going to get peppered by road debris and other crap while driving.
I'd also like to use a common part or material and re-purpose it, rather than having to custom make something myself. To give an example, the rest of the nose cone will be made from a Brute plastic trash can, cut up and attached to an aluminum frame. That has the natural curved shape we want already, and is tough enough to withstand the aero-abuse.
I've thought about slicing a pipe, but not only could I not find a pipe small enough, I couldn't think of a way to adhere it to the hinge. The hinge has holes in it, so we can potentially use screws if needed.
Any thoughts?
Currently building Champrius 4.0! Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
The goal is 70 mpg this time around.
Stats from Champrius v3.2:
The Following User Says Thank You to Talos Woten For This Useful Post:
aerohead (06-23-2022)
