Originally Posted by Ecky
That's a fair point. As you say, economy is not the only thing affected by weight, but brakes are probably not the first place to look if economy is your goal.
So long as your brakes are in good order....not dragging, releasing properly after use.
Which system (drum vs disc ) has the most parasitic loss.?
