Old 06-23-2022, 01:26 AM   #26 (permalink)
cRiPpLe_rOoStEr
Originally Posted by ps2fixer View Post
The newer trucks with the intercooler are something like 525 ft-lbs factory, while mine is 450, but they also have a larger turbo, probably to offset the extra intake air volume in the system.
Most likely the larger turbocharger is there because of the intercooler, not the other way around. The smaller turbocharger may decrease turbo-lag, yet it would limit the air flow at a higher RPM. A colder charge air is also better for reliability under a more extreme power and torque rating.
