Old 06-23-2022, 09:59 AM   #8 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
If you find a way to use that residual moisture extracted by the air conditioner, would be even better.
That would be pretty cool. Unfortunately, both the Camaro and Talon don't have AC. I won't be putting AC on either of them due to where I live we just don't have that warm of weather to justify it.
I did some calculations on how much the usage nitrous would cost for 7lbs. It came out to around $30.00 for 12 gallons of gasoline or 603 miles. On waste solvent it would be worth it to test the numbers.
Pressure Gradient Force
The Positive Side of the Number Line
