Originally Posted by Piotrsko
Rubber membrane sealing tape like for roofing or window installation. Sticky as heck, bends and shrinks, small rodent proof. Want airfoil, stick it with hinge point on outside, want smooth, stick on flat side of hinge.
Julian Edgar was doing things with increased radii corners, not necessarily an airfoil although he did use a gawd awful Gottengen profile windmill blade (mostly because he could get them easy/cheap)
Oooh roof seam tape. A very good idea. I could curve the tip with either a small dowel inside or just layering the tape, depending on how big I wanted it.
I also looked into trying to get an actual wooden airfoil, like for a model airplane or somesuch. But they are all made out of balsa wood and I don't know if that will be able to withstand the conditions. If I did use them, attaching with some screws covered by roof seam tape sounds like it would be secure and waterproof.
Thanks for the idea!
