Thank you for the advice and the links. between the two I would be more likely to do what AndrewJ did with his CX.
As far as staying in lean burn, how can you do that more? I try to stay in the "dead pedal" zone as much as I can (traffic permitting) but it just does not seem to have enough power to get up some long hills and keep a decent speed.
I usually shift to 4th going up a gentle hill to stay in lean burn but Is it more efficient to go from 5th to 3rd going up a steep hill to stay in lean burn?
