Old 06-23-2022, 02:29 PM   #2 (permalink)
Caddylackn
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 51.24 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
I would go with taller tires first, before a gear ratio change, but stick to narrower tires like 65 series. Wider = more drag. Then run just below max. tire pressure, then compare mpg.
Check your mileage on a 30 mile trip against google maps and compare. I run a non factory tire size but I found my odometer matches perfectly, but my speedometer is off by 5%. Not sure how that happens. So my mpg is correct when I calculate it.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
