Old 06-24-2022, 12:01 PM   #27 (permalink)
oil pan 4
Gasoline engines tend to like warm air. I ran a thermostatically controlled air intake set for 94F. That made the carb run a lot more consistently and a lot better in cold weather.
Diesels like cold air above 20 to 50F. It really depends on the engine, turbo and intercooler setup. Every engine is different basically have to test it to figure out what your diesel likes. If the engine is breathing in near freezing cold air (after the intercooler) its more than likely hurting mpg.
