Old 06-24-2022, 08:44 PM   #6 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Not really. I turned the carb only, I don't think I touched the timing and got a 20% mpg boost over a proper carb tune.
The only way to detune the top end is intentionally screw up the ignition timing which would just make it run less efficient or put in a smaller cam or use something like Rhoads hydraulic lifters that are extra leaky from the factory and make it seem like you have a smaller cam at idle for sure and slightly smaller below 2,000 to 2,500rpm then they pump up to full lift by 3,000rpm.
The 2009 Toyota Prius is a fuel injected vehicle. It doesn't have a carburetor.
Currently building Champrius 4.0! Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
The goal is 70 mpg this time around.
Stats from Champrius v3.2:
