Old 06-24-2022, 11:10 PM   #26 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Originally Posted by ps2fixer View Post
You could use metal screen over the exhaust, I think that's how areo civic was done, but it's a long time since I looked through the thread.
Build thread:
https://ecomodder.com/forum/showthre...1-0-a-290.html
Right now the cats are covered by two cat shields made out of aluminum. Those seem perfect, since they are actually designed to withstand the heat. If I were to ever cover the muffler, it would be with something similar, i.e. a thick sheet of aluminum. But at this point I'm not certain I would even gain that much from it.
I used to use chicken wire over air inlets, but this new design doesn't have any on the underside. And I've learned the benefit of leaving outlets open to clear water and debris.
Currently building Champrius 4.0! Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
The goal is 70 mpg this time around.
Stats from Champrius v3.2:
